Just bought a 1996 Cobra w/89k... 2 questions
RE: Just bought a 1996 Cobra w/89k... 2 questions
The E-brake sticking is actually a problem that is a free recall. Just take it into a Ford dealer (Make an apt first, give them your VIN on the phone to verify the free part change) then go in there and have it done. It was a large safty issue with the car rolling away and keeping the brake engaged while driving thus lowering brake life.
For the grinding, everyone else got it.
-Eric-
PS have ford check your car for any other recalls that may need to be performed.
-Eric-
Is it worth buying the Royal PurpleSyncromax? I mean, if its not going to fix the 5th gear grind, i dont think i will spend the money for the fluid.
Recalls aren't free forever. They are usually only active for a certain amount of time & if the work isn't done in the allotted time, you are on your own & need to cough up the cash.
Wick001, if your car is grinding going into 5th gear, odds are the synchro is damaged. IMO, I wouldn't change the fluid. I would make sure the fluid levels aren't low & just top it off. It sounds crazy, but many people who never change the tranny fluid & finally do after excessive mileage - suffer failures immediately after. I would just stay out of 5th gear & drive it until you can afford to have the transmission rebuilt.
Since you likely can't verify when any flushes were done, just leave it be...
Diode Dynamics
28
05-26-2022 12:02 PM
