What is this part
What is this part
This has to do with the good old P1443 code.
Purge sensor or Canister Purge valve? Also, is the purge sensor the same as the purge solenoid? I think people have been confusing the two, and I am trying to find out which to change.
One I can see is right under the strut tower brace. It is plastic and back and it has two hose fittings that are aligned. And the electrical connection comes in from the side (parallel with the hose fittings).
The other which I cant find on the car (but I have seen pictures of), looks like it is made of metal. It has two hose fittings that are not aligned (one is slightly higher than the other), and the electrical connection comes from underneth.
I know this question is rediculously old, but I would really appreciate a definitive answer if someone out there has one. Thanks guys.[/align]
RE: What is this part
This one... I replaced everything in mine when I had the code... First 2 were the carbon canister and the other one that you are talking about... Cleared the code, and driving down the road, came back on...
Went and picked this up, cleared the code...
nmra1965
Other Professional Racing
09-26-2015 10:46 AM
mrappe
09-26-2015 10:16 AM
09-25-2015 06:58 PM
