Kenne Bell
RE: Kenne Bell
Piece of cake install except if you got the big coolant pump that needs to go behind the passenger headlight ,, i did one on a buddys car and it was a pain to drill the necessary holes to mount it there ( have ALOT of drill bits handy) otherwise pretty simple and around 365 at the wheels ---- his hood also didnt fit due to the pulley hitting it a bit --- look into that if you dont have a cowl hood
RE: Kenne Bell
Subsequently my pockets are not that deep, I am selling my Pro-M Meter 855mm calibrated for stock injectors, also selling my Dragon Plenum as it is no longer needed with the KB kit, and the Diablo Predator Tuner b/c the kenne bell chip overides all.
RE: Kenne Bell
ORIGINAL: 04OrangeGT
Thank you...Kenne Bell told me 400hp/410tq @ the rear wheels. I paid 5k shipped...My dyno from 2 days ago was 267rwhp 297rwtq... I hope i make the 410/420.
I found some links for you as to what your expected to gain with a good tune..Hope this helps ya
http://www.pats-world.com/brightblue...percharger.htm
RE: Kenne Bell
So the whole ECU tune does not take care of it? Thanks for the links.
That may work for you...But honestly you might still want to have a professional look at it, if your mechanical skills aren't above average. I wanted to install mine myself....But i just didn't have the skills...
