Next mod?
Next mod?
ok so far i have this sitting in my room
-tunable induction CAI w/ Pro M 85 mm MAM
-steeda underdrive pulleys & timing adjuster
-pypes X pipe w/ 2 High Flow cats
now ... would i see more gains if i got lets say the diablosport predator or delta chip(whichever is cheaper)..... OR would it be better for me to get a TB and plenum and screw the diablosport stuff...
If it is better to get the dibalo sport tuner or delta chip ill be returning the steeda timing adjuster, but if ill see more gains from keeping the timing adjuster and getting a new TB and plenum instead of the tuner, then thats what ill do ... let me knwo what u guys think
RE: Next mod?
go with the throttle body and plenum and keep the adjuster. I don't thing the tuner could adjust the timing all the way to 14. it only advances like 2 or 3 degrees. You should really thing about gears. Thats better than all those ideas.
RE: Next mod?
a chip / tune is a better mod than most think. not only do you get more timing (you can get as much timing as the tuner is "tooned" for) bujt you also get a more powerful a/f mix and can get the fan on earlier for better cooling, correct for gear changes, firm shifts in an auto, turn off the EGR system, turn off the traction control, have 2 step limiters (depends on the chip), etc.
RE: Next mod?
so MD, not clear on what u think exactly ... u think i should return my Timing Adjuster.... and with the CAI, MAM, and X pipe , U/D pulleys...my best last mod would be the predator?.... ive heard that the predator only bumps up timing 2* as opposed to a timing adjuster which i can safley bump up 4*.... it seems to me that u know your stuff better than most people here so thats why im asking u this.... CAI, MAM, x pipe & UD pulleys. so basically it boils down to me getting the timing adjuster and maybe 1 more mod like a TB or maybe a TB and Plenum... or not getting the TB or plenum, returning the timing adjuster and just getting the tuner instead .... u knwo your stuff so im gonna go with whatever u tell me would show me the best gains.... FYI.. i have a 1999 GT 5spd Coupe .. if that matters
thanks
-daniel
RE: Next mod?
ORIGINAL: mdvaldosta
I know people claim that they can tune a car by seat of the pants feel within 2-3 RWHP, but its bull****. If they could, there wouldnt be such thing as a dyno.
If your not going to get the chip custom tuned forget it, and get some gears and a catback. If nothing else, the catback will help sell the car because it will "sound" faster, and the gears will surely make it feel faster.
RE: Next mod?
well i already have flows welded in to the stoc catback so it sounds real nice, and when i put the X pipe on, itll sound even better, PLUS.... gears will cost around 500 installed and a catback is around 400.. i cant afford gears, and i dont care for a catback at this point because im sure it wont make a HUDGE diff.... i already have an X pipe and flows welded to my stock catback... im sure thats good. so do u see where im comming from?... im looking to spend about 300 more bucks than i already have.... thats why i said i want to get the predator OR get the timing adjuster w/ a 70mm TB or something... so i was just wondering which mod id notice more gains with...
RE: Next mod?
I know people claim that they can tune a car by seat of the pants feel within 2-3 RWHP, but its ****. If they could, there wouldnt be such thing as a dyno.
