how much do you burn?
RE: how much do you burn?
So far I haven't had to add any oil to the engine in-between oil changes [8D]
But by the time the oil needs changing the oil level is about in the middle of the dipstick reading, maybe slightly less than 1/2 way
ORIGINAL: 96GT226410
It's not a good thing to burn oil, but face it, it happens. I used to burn about 1 - 1.5 qts. between oil changes.
Your piston rings will wear an engine up to .030. Yours has the miles on it so you most likely have a little bit of oil getting by the rings. It's nothing to worry about until it starts smoking really bad.
