Next Mod!! Youre Vote Counts! lol
#22
RE: Next Mod!! Youre Vote Counts! lol
ORIGINAL: blueherd02gt
A car with full suspension will own a more hp car, I say build the rear/suspension and rock on!
#23
ORIGINAL: amoosenamedhank
This is a very true statement you should listen to. You can make all the power you want. It sounds like your suspension is where you're lacking right now. I'd work on that.
#24
Right, but the gears would help him for that too, plus the upgrade on the rear end wouldn't hurt for future power. The shocks and stuts would also help handling. The intercooler isn't a bad idea. I'd say that as option 2. I built mine for about $300. You will also have to pulley down to see the same alot of boost though.
#25
yea i figured with the sticky BFG drag radials that a built rear end would be a good idea. plus 3.73s will be a nice addition for acceleration since im not getting any hp out of building the rear end.
moose...how/where did you build your intercooler for like $300???
and i probably wouldnt pulley down...if i kept the same one (the 3.6 pulley) i figure it would be at around 10 psi...close to accurate?
#26
if u did make a little more boost then u could just shift a little earlier and your horsepower would come a little quicker.But if your planning on puting stickier tires on it and yes building the rear end is a good idea.The tb and plenum is still not to expensive with the builtrearend.Anyway u go it will only help u down the road
#28
ORIGINAL: Car_Ramrod
#30
built rear should be the only option IMO. Out of all the mods I've done the rearend and slicks were my #1 mod. All the power does no good if you can't get it to the ground.
