performance diff between 02 and 04 gt?
does anyone knows if there is a performance diff. between an 02 and a 04. i know they are both 260/302 but i heard that 04 have bigger valvle and some other upgrades. anyone?
RE: performance diff between 02 and 04 gt?
i think i read somewhere that 04 have large valves, high lift cams, and identical intake manifold runners. This particular model makes cranking the engine easier, too, with a coil on plug ignition system. This increases control and makes igniting the engine easier than ever. Additionally, the engine is designed for durability with an aluminum upper main, upper thrust, and rod bearings. Fuel efficiency is obtained through well designed combustion chambers. chech this out https://mustangforums.com/timeline/2004-ford-mustang/
They are not the same. In the04' (possible 03' also)model car it has a reprogrammed ecu and larger injectors which arepink 21lb ones. not yellowish 19lb ones. Thats as far as I know.
