Wideband A/F gauges
Old 05-06-2007, 06:04 PM
kast1376
kast1376's Avatar
Default Wideband A/F gauges
Its time to start buying the "other" stuff needed for a S/C, starting with a wideband A/F gauge. For those of you that have them, could you post some pics? All the ones I have seen online look fugly, IMO.
Also, what range should the gauge be able to measure from? For example, the Autometer ones start at 10.1. Is that the normal start, or should I need to go lower?
Thanks!
kast1376 is offline
Old 05-06-2007, 06:13 PM
97stanger
97stanger's Avatar
Default RE: Wideband A/F gauges
an A/F gauge is not needed with a s/c...just make sure you get the car on a dyno before hitting boost. I think if you are set on 2 gauges, I would go with a Fuel Pressure and Boost...if you have a 3 gauge pod then id go with the A/F also.
97stanger is offline
jwog666
12-27-2021 08:09 PM
andrew1969
16
01-08-2016 02:48 PM
SteelerNation82
09-16-2015 07:11 AM
Pyrate Dave
09-10-2015 07:30 PM
96stang3.8
09-10-2015 06:42 AM
Quick Reply: Wideband A/F gauges
