Clutch wont release
Clutch wont release
My friend and I changed the clutch ( TO bearing, clutch disc, pressure plate) in my 2000 mustang GT. The problem is that when I press down onthe clutch and put it in gear, the wheels move. Its as though the clutch is not disengaging from the pressure plate. Ijust noticed that the TO bearing was sitting right on the pressure plate fingers and the pressure plate was vibrating enough to vibrate the fork. My car isstill sitting on 4jack stands and isbegging to come down. Help me help my vehicle.
RE: Clutch wont release
No firewall adjuster, I thought it would adjust automatically, might have to look into that. I was looking at the TO bearing through the side of the tranny where the fork is, seems like its on proper but its still touching the pressure plate fingers. The pressure plate wobbles when the car is on causing the fork to shimmy a little also. Could it be the pressure plate was not tightened enough?
ORIGINAL: part0076
junior04
09-28-2015 10:53 AM
ccdguy
09-19-2015 05:20 PM
