gaymasters
RE: gaymasters
ORIGINAL: SVTBill
i dont like my bbk o/r x because it hangs too low and i keep hitting it on sh|t which makes leaks...constantly [:@] or maybe keeps making the same leak worse, idk lol
im at stock height too [&:]
ORIGINAL: 97snakebite
[/align][/align]Hey man, that's exactly what I have done. BBK o/r x pipe and stock mufflers; it honestly doesn't sound that bad on my Cobra. I myself am trying to decide what mufflers to get as well .. kind of leaning towards Magnaflow right now.[/align]
ORIGINAL: SVTBill
i hate them too but 60 bucks to get my car to stop sounding the way it doesnt isnt that bad....bbk o/r x plus stock mufflers [:'(]
ORIGINAL: Aereon
I've heard of someone taking about a 3" trill bit and extensions and putting a hole straight through the mufflers... so a hole through all the chambers from inlet directly to outlet. I have not heard the clip of it tho.. so I dont know.. I am biased against flows tho
RE: gaymasters
well are you rally racing or do you live in hazard county?If you could spend the $$$$ the bassani is modular.4 pieces with clamps, so once its installed, with the clamps a little loose you have your buddy lift up on the assy. and then tighten. It worked wonders and im 2" dropped.The bassani is more $$for a reason!!!!
RE: gaymasters
ORIGINAL: IROLLSALEEN
RE: gaymasters
ORIGINAL: 2002GTAUTOVERT
all aftermarket mid pipes hang low i believe. +1 on the bassani
RE: gaymasters
ORIGINAL: Octane
I still think it is how it is installed. I am no expert, but have done installs on friends and mine a couple of times. They hang at where you tighten it up at. If you hold it snug to the car and tighten, they will stay fairly close to the car. No problems. But as I have said, I am no expert, I haven't seen all aftermarket pipes thus I can't say ALL can be installed snug, but I have had good luck with all I have used...
RE: gaymasters
loosen everything on your midpipe, and take a floor jack and push that ****er up as far as it will go, and leave the jack under the midpipe when you tighten everything.
also, flowmasters suck. [8D]
