Shifter Installation!!! HELP!
OMFG... I got my Tri-Axe today.. I just tried to install it... I got the part where I have to take off the 13 mm bolts that actually take off the stock shifter itself.... I get the socket and it seems very tough... I then put some elbow grease into loosening these 4 bolts... It broke the socket.... I then had tried another 13mm socket... I BROKE THE OTHER ONE!!! I cant my stock shifter out!!!!! What should I do? Put my old shifter back together and go to the parts store and pick up another 13 mm socket??? Those bolts are not there really tight!!! Any Advice on how I will get these off when I get another socket!!!! Help!!
RE: Shifter Installation!!! HELP!
ORIGINAL: wwmost
get some better tools? its not hard at all. try buying a name brand socket
use a wrench to break it free if its that rough... then go to the sockets... or just get ratcheting wrenches the craftsmens with lifetime warranties. i have yet to break one.. got a set of gear wrenches too havnt broke one of those yet either. used them alot then went and got the craftsman set.. good stuff...
zink
zink
I went and got some craftsamn stuff and oh boy that worked... And the key word here is leverage..... One question..... I got the damn thing off... I look in there and there is some transmission fluid in there.. NOt a whole lot.. just some... is this normal??? Or should I clean it out of there?
