help with clutch!!!
help with clutch!!!
i just instaled a new clutch about a month ago... and then all of the sudden one day when ever i would takeoff in first my shifter would vibrate like crazy... almost like i wasnt giving it enough gass.. but i was... and then wen i shifted from 1st to 2chd it was fine... this would only happend about half of the time i would let off the clutch.... anyhelp. ? thanks
RE: help with clutch!!!
ORIGINAL: MustangKid89
i just put in a stock clutch... but i didnt get my flywheel reserfaced becaue it didnt need to be.
[sm=closed.gif]
Who told you not to resurface your flywheel? I wanna go smack them in the face for such a stupid statement. But thats your problem, and I suggest you go have it resurfaced. As for your question on what chatter is: its when the clutch disc is vibrating (chattering) against your flywheel. In your case its caused by the flywheel being uneven from wear due to the previous clutch. A resurface will make it all smooth and even again.
