need help with racing
i have a automatic 2004 anniversary GT, i need to learn how to drag race with this thing, do i keep it in drive? how do i launch it? any tips......im racing a talon tsi soon.
also, people make fun of me cause i have an automatic, is having an auto that bad?
RE: need help with racing
its an auto so im guessing just smoke the tires a little before the race, get em nice and warm, then hold the brake in and give it gas toi the point right before your tires start to spin, then let off the brake and there is yourt launch, i think thats how you sdhould do it with an auto? correct me guys
ORIGINAL: BlackMage
Your car won't like you for it, haha. Now I have a 5spd, but every car prior was an auto. I used to put it in first and runs the gears, and it never made much difference. Plus, some say that's bad for the tranny, but i don't know about that...But just put it in drive, and let it idle, I would NOT recommend revving against your brakes! Just be be quick off the brakes and onto the gas. Use both feet, left for brake, right for gas. And like said above, when starting out, it just enough gas to where the tires just start to break loose a little and when you get going and the wheels are grabbing good, put the pedal to the floor and hang on, haha. I mean, if you ask me, an auto in a drag race is probably better, faster shifts and doesn't burn the tires off the line as bad, depending on tires. I'm not the best driver, and having a stick hurts me off the line, because it's a little tricky to get the right gas/clutch pattern to where I don't burn the tires. So, as far as racing, esspecially if you get a shift kit setup, I'd have to say an auto is better. But as far as driving fun, and burnouts and sliding turns (none of which I do, I swear! haha) a manual is the way to go. They're a lot more fun to drive, allows you to control your car a lot more with a stick...
The sooner you can get to full throttle the better.Hold the brake and push the gas untill just before you start to move.Experiment with this before you get to the track.It's OK to shift manually but just don't hit reverse by mistake[:'(]Get a shift kit or a tune that changes the shift pionts.
I'm an auto too, and I have done all of the above things....an aftermarket tourqe converter (which I don't have) will allow you to reach higher RPM's while holding the brake on. Gives a lil better launch. But, yea resist the urge to slam the pedal down when light turns green, you'll break traction, especially if your not stock.
hey emann0007 i don't know if u got ur hypertech yet. but when i had one i went to the dyno and it gave me an A/F ratio of 17:1 until 4500 so as u can imagine it felt like a dog until then. got a diablo for alittle more and it made my car feel much better also ut has more features. havn't taken it to the dyno yet bu the SOTP feel is deffiently there
I actually posted a new thread yesterday about chip suggestions for an automatic 97 GT. I don't think they make a diablo chip for pre 99's... and yea I heard the hypertech was crap from quite a few ppl, so I am open to suggestions because it will be a couple of months until I purchase the gears and the chip. Thanx!
09-29-2015 03:23 PM
mungodrums
09-28-2015 10:54 PM
mungodrums
Suspension
09-24-2015 10:12 PM
