Rear end??
Rear end??
Anybody know were I can find a diagram of the rear end of my car 2002 GT. Me and a buddy of mine are gonna put 3.73's in and do the bearing's while we have it apart. He asked me if I had a diagram of my rear or if i could get one. I tryed to google it but no luck. Any help would be appreciated
RE: Rear end??
Hacking Ford Sites EFF TEA DOUBLE YOU!!!
1) AXLE HOUSING
2) COVER GASKET
3) AXLE SHAFTS
4) AXLE BEARINGS
5) DIFFERENTIAL CASE
6) SIDE BEARINGS
7) RACE
8) SIDE GEAR KIT
9) SIDE WASHER
10) GEAR KIT
11) WASHERS
12) SHAFT LOCK
13) SHAFT PIN
14) PINION GEAR SHAFT
15) RING and PINION
16) INNER PINION BEARING
17) INNER PINION GEAR RACE
18) OUTER PINION BEARING RACE
19) PINION BEARING SPACER
20) OUTER PINION BEARING
21) PINION SEAL
1) AXLE HOUSING
2) COVER GASKET
3) AXLE SHAFTS
4) AXLE BEARINGS
6) SIDE BEARINGS
7) RACE
8) SIDE GEAR KIT
9) SIDE WASHER
10) GEAR KIT
11) WASHERS
12) SHAFT LOCK
13) SHAFT PIN
15) RING and PINION
21) PINION SEAL
Dragonus18
09-09-2015 01:21 AM
