Suspension Squeek
Suspension Squeek
This very well may just be something I need to get underneath and look for, but I figured I'd see if anyone knew. I've got this squeek in my suspension. It mainly does it when I turn corners at speed (like turning at 10 or 20 mph as opposed to after stopping at an intersection), however today going to lunch I noticed it did it several times. It doesn't happen that often but I have one turn out of my neighborhood that I notice it doing it at almost every time. I'm sure it's nothing terrible, but I may be selling the car soon so I want to get rid of it. It sounds like a metal sliding or rubbing on metal type squeek like something is actually shifting in the suspension as I give it some sideways force. Can anyone think where to look first or if there's anything common on these cars that may have these symptoms? I'm not the best with suspension so I'll take any ideas I can then get a better idea when I get under it. The only things I can say is that it sounds like it's from the back, and it doesn't sound like any type of joint, spring, shock or anything of that nature. Thanks in advance guys.
RE: Suspension Squeek
It may be the power steering gear shifting on it's mounts and creaking--TSB 05-14-3 is the Ford fix, here's a link I did describing my DIY fix...
ORIGINAL: fiad06
That happened to my car also...i have an extended warranty so i forgot what the problem was....I am hinking they replaced the control arm, because it looks new...I dont remember exactly
ORIGINAL: cliffyk
Hmm... I think it might have been one of the bolts on the exhaust. I sprayed it all down with some lubricant and didn't hear it, we'll see. I'll have to get down there this weekend and check and make sure all the bolts are tight.
Matt's 95 Stang
10-05-2015 07:16 AM
