CAM ??
CAM ??
wats that difference between blower cams and NA cams
Comp Cams Stage 1-3 NA Billet camshafts
Great performance gains and Comp cams go hand in hand, stage 1 cams can use factory springs, stage 2 and 3 require High lift springs. Stage 1 Cams great forN/A or Nitrous cars with Bolt ons, stage 2 and 3 great for engines with head work, increased compression, stroker engines etc. Call for your application. Custom N/A cams also available.
Stage 1
100721
Stage 2
100722
Stage 3
100723
1099.99
Comp Cams Stage 1-3 Forced Induction Billet camshafts
Great performance gains and Comp cams go hand in hand, stage 1 cams can use factory springs, stage 2 and 3 require High lift springs. Stage 1 Cams great for Forced Induction(supercharged, Turbo Charged) cars with Bolt ons, stage 2 and 3 great for engines with head work, stroker engines, increased boost, turbo Chargers etc. etc. Call for your application. Custom cams also available.
Stage 1
100731
Stage 2
100732
Stage 3
100733
$1099.99
Stage 1
100721
Stage 2
100722
Stage 3
100723
1099.99
Stage 1
100731
Stage 2
100732
Stage 3
100733
$1099.99
RE: CAM ??
Look at the specs on the two different cams. You can see the difference there. Look at the lift, duration and lobe separation. Comp cams knows what is best for your app. that's why they separate them in N/A and blower. If you know that your going blower and want to go ahead and get the cams then get the blower cams. Your car will run fine with them you just won't get as much of a hp gain as you would with the N/A cams. When you install the blower and get it retuned then you will see better #s than you would if you had the N/A cams.
junior04
09-28-2015 10:53 AM
