Time for a tuneup?
Old 05-14-2007, 06:59 PM
02DKBLUE
02DKBLUE's Avatar
Default Time for a tuneup?
I have a 2002 GT, i got it in january 06 with 18,000 miles. Since then i have only been regular with changing the air filter and the oil. Now it has 41,000 miles on it and i was wondering if there is any other engine matenience that i should be doing: spark plugs, fuel filter, transmission fluid(its an auto), maybe some fuel injector cleaner? i'm not sure what all should be done at this point. I read something about replacing/checking the PCV valve? She runs nice now and i want to take care of her for the future. Thanks in advance.
02DKBLUE is offline
Old 05-14-2007, 07:04 PM
02 Ninja
02 Ninja's Avatar
Default RE: Time for a tuneup?
Look in your manual and it will tell you when your car is due for the scheduled changes. You shouldn't have to do anything right now unless you're having problems. I believe your 1st check up should be around 75k. No fuel cleaner or anything like that
02 Ninja is offline
Old 05-15-2007, 04:08 PM
joeunmd
joeunmd's Avatar
I Disagree. This guy has put a decent amount of miles on his car in a little over a year. Leads me to think he should follow a stricter schedule.
At this point, andI believe the manual will confirm this, coolant flush, auto tranny flush w/filter change, fuel filter, air filterand PCV valve change was due at 30,000.
The tranny and coolant can be done at Ford for about $300.The rest you can do at homeeasily enough.
I have an01 GT vert auto and these items improved the tranny shifts and fuel economy. I do recommend Ford for the tranny, they use the right synthetic fluid. And No, I don't work for them.
joeunmd is offline
mungodrums
10-07-2015 04:01 AM
clowe1965
Carolina Regional Chapter
34
09-28-2015 09:18 PM
StalkerGT
09-25-2015 02:41 PM
09-08-2015 11:50 AM
Quick Reply: Time for a tuneup?
