Removing axles HELP NOW!!!
RE: Removing axles HELP NOW!!!
ORIGINAL: uberstang1
So ford tech's don't know what teh shims look like??? They shouldnt be working on gears considering it looks like they have no clue what there doing, just because there techs doesnt mean there qualified for every job, once again gears are generally a job you want someone to do that has expereince in doing them, which they apparently have none
ORIGINAL: timeformiller44
*** you
But anyway in your pic the skinner part is the shim and the other part is the bearing carrier race. And to get the pinion out I put the nut back on the end of the pinion (so you don't f up the threads)and tap it out
ORIGINAL: stanggang1892
Are these the shims?
To get the pinion gear out you have to make sure you unbolt the driveshaft and the pinion flange on the back of the pinion gear. Then use a punch to hammer it out. It is in there pretty snug, but will come out.
Take your time dont rush it. You will forget a step and have to tear it back apart if you get in a hurry. Dont get the "well thats close enough attitude" either. Just look everything over and make sure it goes back together the way it came apart. Print off the site above and the PMs, then follow them and it WILL turn out perfect
[align=left] [/align]
The bottom one is the shim,,the other is the Carrier Bearing Race...
take off the pinion nut,knock or drive off the flange(use puller is you have one)most dont.....rubber mallet gently(with the nut a few threads on thepinion,,,,tap it out(it will be alittle difficult to remove).....catch it on the other side....
[blockquote]quote:
[blockquote]quote:
[/blockquote]
*** you
[/blockquote]
I don't think that is called for because uberstang is 200% correct.
_____________________________
Thanks Bramas, by no means did I want to sound like a jerk, just saying that gears aren't really a do at home mod for a first timer thats all.
[blockquote]quote:
[/blockquote]
*** you
[/blockquote]
jwog666
12-27-2021 08:09 PM
KingRando
10-02-2015 08:06 AM
09-24-2015 09:18 PM
