Fuel Injectors
RE: Fuel Injectors
After some searching, I want to try unplugging them one at a time to see if the tick is the injectors and to see which one it is. Are there any good writeups on how to do this? Do I have to unplug one, start the car, check for tick, turn off the car, replug injector, unplug next and so on?
Thanks for any help!
RE: Fuel Injectors
I wouldn't reccommend unplugging an injector. Having no fuel go into a combustion chamber = bad. Are you sure it's not something else ticking? I have never heard on an injector ticking. What mods do you have? Is your car force fed? If not just replace the injectors with OEM replacements.
RE: Fuel Injectors
Well basically I put a screwdriver on the fuel rail and it gets alot louder and clearer. My car is stock. I did some searching on here and that's where I saw the stuff about unplugging them, etc. Some people say it's normal. They just started doing this within the last couple of weeks and Ford said nothing was wrong. It's just annoying to me to hear it and it seems worse when the RPMs go up.
RE: Fuel Injectors
Would these work:
http://www.americanmuscle.com/vehipefuin24.html
Would I need to do anything? I assume that these 24# ones are larger than smy stock ones.
RE: Fuel Injectors
ORIGINAL: pikuoff
Would these work:
Would these work:
