Torque converter gurus...
I will be installing a BCautomotive 3600 stall in my car soon in hopes to run 12.5's in the 1/4 with my current mods. The previous owner ran a best 13.4 at 108 on stock tires and Ive since added drag radials and BMR upper/lwr c arms. I believe the car will run high 12's as it sits and hoping for a 12.5/108 or so after the converter. What stalls are some of you running and what improvements did you make after the converter? Thanks.
RE: Torque converter gurus...
ORIGINAL: droptoppony
Are you going to keep this car N/A? If so i would do a 4000-4200 stall to get the best times...thats what seems to be the best on these N/A modulars especially 4V's
Did BC tell you what RPM stall to get? Did you show them your dyno graph? Thats the best way to determine what stall you need...They will be doing my TC also but i'm waiting until i'm done before my final dyno then i'll have them hook me up.
My stall is a 3200 from BC and is defiinately a little low... Darrin reccommended me to go higher but Iwas dumb of courseand went with my own opinion. I would say with my limited knowledge, a 3600 would be good for your car if you keep it N/A. Tires are a must though, my 315's don't stand a chance now.
