pi swap help. Starting tommorow
I am planning on swapping a pi intake and possibly cams(if time permits) tommorow. My question is about the nipple. Is it called a tube asy (F75Z-8555-AA)? What is the difference in the npi and pi nipples?? Also any tips would be appreacitied?
RE: pi swap help. Starting tommorow
when I did mine I tried to leave as much as possible connected together.Some instructions say to unbolt the egr from the exahaust manifold you dont have to do this you can just unscrew it from up top and bend it out of the way.....and dont forget the bolt tightening sequence as well GOOD LUCK
bryan616fl
01-25-2019 09:07 PM
KEM Motorworks
08-14-2015 10:13 PM
