Adjusting the clutch pedal w/ a Steeda quadrent
My clutch pedal is the highest sitting pedal by a lot. I have a Steeda adjustable quadrent and fully adjustable cable and I don't have the instructions for it because I had it installed at a shop. I was wondering if anyone knew how to drop my clutch pedal because for one it sits to high and two it catches way up high making it a bitch to drive. Thanks.
RE: Adjusting the clutch pedal w/ a Steeda quadrent
I have the firewall adjuster and on mine there are two places to adjust the clutch. Not sure how much it adjusts the pedal but here are the two. On mine the firewall adjuster is one. Located right next to the brake master cylinder and it twists in and out clicking every 1/4 turn. Also since I have an aftermarket cable the cable has an adjustment where it hooks up to the pressure plate. you can find that on the drivers side of the transmission it will be hidden by a little cover that sticks out and is held on by one bolt. Just look for a cable that runs into a cover and there it is.
Hope this was helpful and sorry for the novel.
Yeah I know how to use the firewall adjuster I just wanted my clutch to engage a little lower and for the pedal to sit lower. I know where the cable goes into the trans so I will have to take that cover off and adjust it there like you said. Thanks man.
09-16-2015 07:53 PM
09-08-2015 11:50 AM
09-01-2015 08:16 PM
