Brake Pads and Rotors
RE: Brake Pads and Rotors
Just did cross drilled rotors on mine recently. Got them off ebay and they are good quality.
Went with ceramic pads to eliminate the brake dust from getting all over the rims. Got these from carquest.
ORIGINAL: DTK
ORIGINAL: DTK
ORIGINAL: MCanavan6
[/quote]
Yes they are in that they get rid of the gases that build up between the padwith normal rotors.
You can get slotted as well but these will wear the pads faster as they "shave" the surface of the pad thus preventing pad glazing. These are great for road racing though.
I painted the "hat" on the rotor with Caliper paint and baked it on with a heat gun so that with the rims on you won't see a rusty hat section like with most rotors.
[IMG]local://upfiles/47197/75B6480A03C84AAFAFD3A681539A9663.jpg[/IMG]
ORIGINAL: airborne22
not to hijack but what all does an install of new brakes intail... I know the rotors are a direct swap but how hard is it to change to new brake pads?
The front is pretty easy compared to the rears.
