Almost Wrecked my Stang HELP
#31
RE: Almost Wrecked my Stang HELP
I dont have a modern stang but I'm pretty sure the stang has a negative ground system, my ranger does. Why would ford put a positive groung system? On positive ground systems, you should allways disconnect the positive cable first. On negative ground systems, you allways disconnect the negative cable first.
#34
actually Quicktime, it can run with the battery disconneted. one time my dad's battery died in his truck and we didn't have jumper cables, so i pulled up, left my car running and took the battery out so i could put it in his truck and start it
