Car smokes!
RE: Car smokes!
well if i do a compression test on it, it should tell me if it the block is still good right? if the block is still good then that gives me a good reason to do do heads and cams since the headsare smoking?
RE: Car smokes!
ORIGINAL: 97mustanggton18s
Correct me if I'm wrong, but a compression test tells you if your pistons or rings are bad since that is where the compression is. Even if you get a compression test and the results arebad, you still shouldnt need to replace the block, just the pistons.
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
