Leak behind rear passenger wheel...
RE: Leak behind rear passenger wheel...
I would plan on 1-1/2 hours labor, you have to:[/align][ol][*]remove the wheel, and the ABS sensor (or at least move it back 3/8" or so;[*]remove the differential cover (draining the oil in the process);[*]remove the lock bolt and pull the spider gear shaft;[*]push the axle in and remove the C-clip, pull the axle out;[*]replace the axle seal (I'd do both sides once I was this far);[*]replace the axles and C-clips;[*]remember to remount the ABS sensor(s);[*]replace the spider gear shaft and lock bolt;[*]replace the rear-end cover;[*]fill it up, remember to use friction modifier if the oil doesn't have it already (most synthetics do);[/ol]
Yay, take it for a ride...[/align][/align]
ORIGINAL: 99mustanggt
If you repair it yourself, be prepared for one of the worst smells ever when you pull off your differential cover.
Oh yeah, I hear Ford is using Dana diffs in their new cars now. That's going to suck for Ford...
Dragonus18
09-09-2015 01:21 AM
09-01-2015 08:16 PM
