Injector Size?
Injector Size?
I'm in the middle of building a new motor for my 99 GT. I have a stock block, with forged internals, Ross pistons, Fox Lake stage 2 heads, Fox Lake's P-51 intake manifold, and Comp Cams. Since I'm not getting a supercharger anytime soon, can I use the stock fuel injectors, or should I go to a larger size? Thanks in advance for your help!
RE: Injector Size?
I would suggest a larger injector for your application. The stock injectors can hold up to ~320rwhp. It seems like you are goign to make a little more than that. You should at least go with the 24 if not the 36 lb. ers. It will put less strain on your fuel system if you don't try to max out a fuel injector!
RE: Injector Size?
ORIGINAL: 99STEEDAGT
You might want to look there.
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
