Installed Pro Kit Didn't seem to settle (Updated pictures!) IS this the right hieght?
RE: Installed Pro Kit but didn;t lower the front much! Needs to settle? (Pics)
That's why I'm kinda pissed. I will probaly end up with some steeda sport springs for the from from someone locally if it doesn't drop any more
looks great alot lower then mine but you have 235 55 17's upfront which is 10MM taller then my tires i have 235 45 17's and will be putting some 245 45 17's whis is about 3 mm taller then what i have now. Looks good with those tires though. I couldn't run such a big tire cause of my rears being 35's
It does seem like it settled some from last nights south beach drive. Here's some pictures, still seems too high but alot better.
Sorry for all the pictures but just want to make sure you can make it out
I just installed a set of Eibach pro-kit on my 03 convertible. I have 18's, 265/35/18's all around (waiting to find 295's for the back). It didn't look real low at first, but after these pics, I think it settled a bit. When you installed the front springs did you make sure the bottom of the spring fit into the receased notch?
[IMG]local://upfiles/67093/4396E5685CD84E40A7824A102D4A3D6D.jpg[/IMG]
[IMG]local://upfiles/67093/C22481934BAF418695BE63112EBD0F49.jpg[/IMG]
Does anyone remove the rubber from the bottom of the front springs or the top of the rears? May that makes a difference, I didn't on mine, but then again I didn't know if that was an option.
