blower noise
RE: blower noise
why would u not get it.. tell them u didnt install it until you had enough money and time for a tune. and just put it on and it started. i doubt they will argue with you after you spent some thousands on their product
RE: blower noise
ORIGINAL: svt_97cobra
[hr]
Do all vortechs have them. I dont think mine has an idler pulley
ORIGINAL: lizzyfan
Flanged and sits next to the blower pulley
What does the idler pulley look like?
[hr]
RE: blower noise
ORIGINAL: 2002GTAUTOVERT
This will stop you from procrastinating in the future, eh?
RE: blower noise
ORIGINAL: lizzyfan
+1
RE: blower noise
I had a similar noise on my ProCharger. Took it to the shop for warranty repair as they though it was a bad bearing on the idler for sure. Ordered the new idler and bearing and sure as **** it was just the backing piece that held the idler on the bracket. It cracked and the two bolts were holding the two pieces on the back. I don't know how vibrating aluminum can sound like a bearing but it varied with RPM and everything. 5 minute fix, no charge, sounded like clean sex again, no more dirty sounds.
I hope it's a bearing or bracket in your case...
RE: blower noise
Pull the belt off and spin the blower. If it seems nice and smooth, try the idlers like they are saying. If this has no result, get some mineral oil (the clear type) and work it into the idlers (spray it on and work em back and forth, wipe excess) make sure to wipe any excess off before starting the car (or your gonna have belt slip ) and see if the noise goes away.
