what would cause a rough idle in park?
Recently, everytime I start my stang she kind of has a rough idle in park. The rough idle only appears when in park and also has a slight bigger cam type of sound. The car is an 03 auto with 35k on it. The car idles around 800 ish and dips a little.
RE: what would cause a rough idle in park?
Have you done anything with your tuner? If so, try taking everything back to stock and then disconnecting your battery for about 15-20 min and letting your computer reset itself.
ORIGINAL: lsustang04
Yeah I have used the tuner to adjust shift firmness, disable rear 02s, andmaxed spark advance.
I used the tuner and put everything back to stock. Also, unhooked the battery for 15 minutes, but the rough idle is still happening in park. The car seems to vibrate a little. Do you think it's the iac? When in drive and accelerating everything is fine.
