Getting roters cut... will it unwarp them?
Old 05-22-2007, 11:37 PM
czwalga00gt
czwalga00gt's Avatar
Default Getting roters cut... will it unwarp them?
If a car was traveling at say 135/140 mph and said car hit the brakes with ****ty rotors and brakes... and the rotors happen to warp (now squeek once per rotation). Will cutting the rotors fix this would you need new rotors completely.
czwalga00gt is offline
Old 05-22-2007, 11:44 PM
8banger
8banger's Avatar
Default RE: Getting roters cut... will it unwarp them?
Yes,,,,providing they are turnable....there are certain specs(thickness required) anything under specs(cannot turn)....,,,buy new ones....also the thinner the rotor,,less heat it can desipate....will likley warp again..at some point..especially if your hard on them...like track use..LOL...
8banger is offline
Old 05-23-2007, 12:18 AM
amoosenamedhank
amoosenamedhank's Avatar
I would look at upgrading the brakes with as much power as you are making. Like 8banger said if they are turnable it should fix it as long as they aren't to bad. I would still look at upgrading though.
amoosenamedhank is offline
Old 05-23-2007, 12:36 AM
Sniper6677
Sniper6677's Avatar
+1 to all above comments
if they can be cut it will fix it until you do the same thing again....just get slotted rotors of some kind cuz it s just gona happen again
Sniper6677 is offline
JimR1
04-26-2011 05:55 AM
sandcracker21
05-24-2009 08:53 PM
ryan mauchamer
4 Cylinder NA and Turbo
02-26-2008 11:08 PM
steve75
02-03-2008 12:50 PM
98PONYGT
06-26-2007 02:43 AM
Quick Reply: Getting roters cut... will it unwarp them?
