Top End Engine Kit
RE: Top End Engine Kit
What kind of power are you looking for? Aftermarket companies use stock castings and port them out themselves. I've heard that Patriot Heads have had some problems in the past with their heads but now they're much better quality. There's also VT and Steen. There are more companies out there. As for the intake... Typhoon makes a good intake and I heard that BBK is just coming out with one.
ORIGINAL: 98BlackBeast
I'm looking to get some where close or around 350hp. the closer the better. i thought about doing injectors with the heads, cam and intake...
so far...im having problems with the patriot heads
mysterious oil disapearing (in the process of fixing that)....runs rough sometimes....going to get it dyno tuned soon as i sort my oil problem...ill let you know my numbers when i get it dynoed but i dont think ive made much of a power improvement from them...but ill let ya know if your serious about them when i get the numbers
ORIGINAL: code3GT
Save your pennies and do ALOT of research.
ORIGINAL: ZW99GT
Keeping it a 100% streetable is gonna be tough.
Check for oil pulling from the valve covers into the intake. I'm happy with the patriots. I wish I had a little bigger cams tho.
ORIGINAL: code3GT
did you have to get a tune after the head install???
