Procharger brackets...
What is required to make a procharger set up thats made for a 96-98 car work on a 03.
I found a charger with intercooler on a 96 comes with all mounts and everything for $2300. Figured I'd have about $3000 in it tuned on the car....
RE: Procharger brackets...
I have a bracket that is required for your car. I bought a used procharger for a 2000-up mustang and had to buya different bracketfor my 99 since the brackets are different. New from procharger they are about $300 I will sell it for $150.
ORIGINAL: 99StangGTTN
If I buy the kit I'll buy your bracket If I can't find one cheaper. Thanks alot in advance though...
You think there would be any issues making it work? The charger itself doesn't make any wierd noises or anything and is suppose to have around 26000 miles on it.
The bracket should be the only major difference. Everything else should work just fine (all the plumbing and what not). You may need some washers and different bolts. The idler pulley for the Procharger may be a little different on the 96-98 kit than on yours.
Dragonus18
09-09-2015 01:21 AM
Black_GT_02
08-20-2015 01:26 PM
