Need Help Now!!!!!!
RE: Need Help Now!!!!!!
ORIGINAL: amoosenamedhank
Just take the drive shaft off and pull the cover off(all the fluid will come out so have a pan). Then replace the gasket, and bolt it back up. Make sure to put new fluid it in.
ORIGINAL: Pitt
Think he is talking about the seal (small one) that goes on the driveshaft side of the housing. Pretty sure you would have to unbolt driveshaft from the flange on the diff housing (pinion), remove the pinion nut to remove the flange. Then you have access to remove the seal. The part Im not sure on is that when you loosen the pinion nut, you also remove the preload on the pinion bearing. Preload is set with a crushcollar that goes towards the inside of the housing on the pinion. I cant remember if you can remove thiscrush collarthrough the space made when the seal is removed or if you have to take the entire LSD assembly out. You would change the crushcollar with a new one, then get an inch lb. torque wrench and after reassembling everything you can torque the pinion nut to8-14 inch/lb. Or you can skip all that, just change the seal and hope your previous preload was only about 8-9 inch/lb and since being from 8-14 inch/lb is within specs then you can torque it a bit more to like 10-14 inch/lb. Hope this helps some and if someone sees anything wrong here, please correct me.
ORIGINAL: SINISTER
This is good to know, I think I am leaking gear oil from the pinion seal as well. Going to have to jack the car up and take a look.
