i have no idea what is wrong with my car!!!!! i went to start it today and as soon as it clicked over the car died. i tried several times to start the car and each time it started and each time it proceeded to died. the only way that i could keepmy car running was to rev the engine, as soon as i lifted off the gas, the car died. what is wrong with my car???
had this problem once, did everything to try and fix it... the problem was discovered at my battery terminals. they were dirty, spent 3 dollars on a new clamp terminal, problem solved.
Well someone here has a pic of the IAC to show you what to do. To check the MAM make sure its standing up right and all the bolts are tight. The MAS needs to be checked for water. I took mine off the MAM and shook it when I had an idle problem and it had a ton of water in it. I took a blowdryer to it for about 15 minutes and all worked well afterwards. To clean the IAC just take it off and rub it down with carb cleaner.
