Brakes are making a funny noise.
Well my brakes have been making a funny noise for about a week now. It sounds like it is coming from the caliper because we checked the pads and they are fine. The only weird thing is that it is both of the fronts ones. And it happend at the same time. It doesn't matter if im still or if im moving. When i press the brakes it makes popping sounds. My buddy says i might need to rebuild the calipers. Any ideas?
RE: Brakes are making a funny noise.
check all the bolts on the caliper brackets and remove the slider pins and lube 'em up real good with some delectric grease or caliper grease (they are the same thing, both silicone based). you can pick delectric up for $.99 at shuck's.
musnicki
09-23-2015 07:11 AM
Dragonus18
09-09-2015 01:21 AM
