TECH : How much do you really know"
OK so the mystery is....
My car threw a code, had it checked out. It was bank 1 sensor 1. "o2" so I replaced it and disconected the battery all night. To reset the comp.
The code came back. so I took the o2 out and checked it , looked fine. so I tried again. Still came on.
any ideas why its throwing the same code, with new parts.??
RE: TECH : How much do you really know"
ORIGINAL: JD1969
Could the wiring be melted/frayed? Also just disconnecting the battery might not clear the code, clear the code with a scanner and go from there.
Bank 1 is the passenger's side (the #1 cylinder side). I've seen a number of comments here and on other forums claiming it was the driver's side--this is not so...[/align][/align]Did you change the passenger side sensor?[/align][/align][/align]
ORIGINAL: BuzzCut
What was the code. Then I will shoot recomendations
ORIGINAL: cliffyk
I did and the code came back.
So I thought I had swaped the wrong side.
Thats when I came to the Forum with the questions of the banks.
I'll try and swap out that side again.
