NA or FI!!!
#21
RE: NA or FI!!!
ORIGINAL: 1BadSonicBlue02GT
Ask Code and ZW99GT what they'd reccomend. As Far as the easier and more streetable of the two would be. they can tell you first hand
#22
RE: NA or FI!!!
ORIGINAL: JD1969
I am sure he wants to spend $10k+ on the motor, gut the car and only run low 12's on motor. Not taking a shot at Code here, his car is nice, but he built to run on spray from the get go, but decided to see what he could do N/A before hitting the N2O. A built *** N/A 2V will have a tough time making 330 rwhp and if LS1's are your target you better run FI of some kind, because they run mid 12's with bolt ons in most cases.
#25
RE: NA or FI!!!
ORIGINAL: JD1969
#26
RE: NA or FI!!!
If u want a lot of power go f/I or heads/cams/nitrous.If u dont want nitrous go f/I all the way.I learned the hard way.I did heads and cams but i wanted more power.Now i got the botter on top of that lol.And my drivablitly is really good with stage 2 heads and cams
#27
RE: NA or FI!!!
It really shouldnt even be a question. You HAVE to go FI in some way shape or form to go fast with these cars. The EASIEST way, would be to slap a 150 shot on it, the most expensive/least gratifing way would be to do a big N/A build, and the BEST way would be get a Vortech/Procharger.
You say you have $9000? S/C, no questions.....
Nitrous powns superchargers like all the time. I thought you guys knew that already.
