Replacing clutch What one should i get
I pulled the motor in my car due to a loud knock (Bent valve). While its out i want to change the clutch because it was starting to slip. It currently has a spec 1. Should i get the spec 2 and where is the best place to order it from?
RE: Replacing clutch What one should i get
Im not sure if I like my stage 3 spec clutch. Ive had it for a month now.The puck design makes it so you really cant slip the clutch out when starting off regular. I kinda have to take-off everytime, my girlfriend doesnt like that EVERY time. Sometimes it will catch at different pedal heights too. I was going for the stage 2 but the shop I went to said they sell so many of the 3's with great responses. I would have not gone with the puck design clutch unless its a track only car.
Hope I helped.
Hope I helped.
ORIGINAL: ZW99GT
you have the infamous T-45 transmission
ORIGINAL: kendiesel
My car is a 2000 gt. What manual transmissions did they come with? All i know its a tremec.
http://www.moderndriveline.com/Technical_Bits/T-45.htm
