Shifting problem
Shifting problem
My 02 might have a little problem that i wanted to run by you guys. whenever i shift from 2nd to 3rd it sounds like a hard knock wheni release clutch. Kinda sounds like it pops into gear... if i let off the clutch real easy, its not very noticeable, but what fun is that :P So if i go from 1st to 2nd and just release clutch normally sounds like the rear is hitting on something.. it drives real real smooth.. no probs, but i can feel that knock.. could it be driveshaft?? someone said it might be my gears.. whatu think
RE: Shifting problem
it only makes the sound when you let it out? can you feel anything in the shifter moving/griding when you let it out?
If its when you let it out, its probably either the TOB, or maybe nothing at all. Is it really noticable, or just a very quiet sound? Does it do it alot more when drivign hard?
Lets say im in first gear and the instant that i put it into second gear i feel a hit around the driveshaft area. Feels like something hits or moves.. sounds like a "BOOM". This happens everytime i shift from 1st to 2nd or 2nd to 3rd. Besides that the car drives like a dream. Anyone have any ideas
I have this same problem, I brought it to the dealer (still have a warranty) the tech drove it and said that it is a normal thing for these transmissions. For me it just sounds like a knock when I go from 1-2 and sometimes 2-3, but its not loud at all.
RWD vehicles have inherently more "slop" in the drivetrain than FWD (manual transmission accentuate this to some degreee) and I have noticed that the drivetrain in our cars has a bit more than other RWD cars I've owned (a Mercedes 300E, and a couple Miatas). However with appropriate awareness of this, and acquired skill, there should not be any "booms" or other nasty sounds.[/align][/align]It's common to get a bit of chugging when shifting in the lower gears and not getting the revs right (you'll see trucks do this all the time), and sometimes you get some mild clunking/chunking when tooling around a parking lot at low speeds--but if it happens all the time regardless of how you shift then somethings wrong...[/align]
