2v to 4v
2v to 4v
i know this question has been asked many times so i guess ill ask, has anyone converted their 2v to 4v. what do u need besides the new heads, headers, and 4cams.
do u need a new ecu
what intake manifold do u need,
and is there problems doing this, like install lol
any help thanks
do u need a new ecu
any help thanks
RE: 2v to 4v
pretty much you will need a whole new block. not quite but a 2 ta 4 swap on a 2v block isnt fun. if you want a 4v buy a cobra. otherwise you'll need.
A new motor basically.
new wiring harness
i cant remember if our trannys bolt up to a 4v block or not
new ecu
a hell of alot of time money and patience
new wiring harness
new ecu
RE: 2v to 4v
ORIGINAL: 1BadSonicBlue02GT
new wiring harness
new ecu
new wiring harness
new ecu
You will need heads, cams, timing componets, intake, timing cover, ecu, and a few minor things. It will cost alot.
RE: 2v to 4v
ORIGINAL: oxfordgt
You dont need a new block. They are the same castings. Only difference is is the 03-04 block has 4 bolt mains and all other cobra blocks are aluminum.
new wiring harness
new ecu
new wiring harness
new ecu
but you might as well buy a cobra motor and drop it in. as opposed to doin it all to your own block. i cant see it costin a whole lot more. And it'll definitely be easier then screwin with all the timing chain crap and so on.
Ford sells the 03 cobra motor without the blower or the accessories(alternator, A/C, etc) for 3000 dollars
