Intermittent Low Oil Light??
Twice now the indicator for 'low oil' goes on - - but I know the oil level's fine (checked dip and just changed oil, too). If you shut down the engine and restart, the light goes out.
Huh? Sensor? Anyone? What's a guy to do?
-96 Cobra
-96 Cobra
RE: Intermittent Low Oil Light??
ORIGINAL: xlts250
I dont think you have to worry about the pump, you have an oil pressure guage for that. Were you parked on a slope when it came on? I know mine has come on a couple times because of that.
Two others have told me their sender went out.
Sounds like it might be a common thing. Anybody else?
The dash gauge shows normal - - but I'm not crazy about relying on that.
And nope - - this was on a flat just cruising.
I better not run it until fixed, eh? Hate to miss out on good convertible weather.
Nuts.
Nuts.
Ya, check your oil and you'll be fine, just because you are low on oil doesn't mean you'll be low on oil pressure. Its a bad idea to rely on the guage to tell you if you arelow onoil on any vehicle, thats not what its for. Im just saying that your low oil light isn't based on the oil pressure as far as i know so i doubt its the pump.
Well - - here arethe results.
First of all there was a bum low oil sensor. Replaced.
Second, leaking o-rings near oil filter/oil cooler. Possibly just an age related issue. Replaced.
Weather's warm - - top's down - - and no oil light.
96 Cobra Convertible 52,500 miles and counting.
