aluminum driveshaft
aluminum driveshaft
is it hard to isntall a for racing aluminum driveshaft on my own.... it already comes balanced i belive so i wont need to do that... i think you just bolt it in and go.... but is it hard to bolt it in... do i have to remove any parts of my exhaust or anything like that?
RE: aluminum driveshaft
well i think imgonna be getting 410 rear end gears and i hear when u use more than 373 it will cause vibrations so i guess ill just spend an extra couple hundred for no vibrations and maybe a smoother accel.
i guess i didnt answer the quyestion too well... the only real benefits of an aluminum dirveshaft, from what i understand, are that u will get rid of vibrations(if u even have them to begin with) and there is less rotational mass so it may accelerate smoother than it did before... other than that i guess its pretty worthless... if i werent getting 410s i wouldnt get the driveshaft
ill let u know as soon as i get it on... i might even put the aluminum drive shaft on before i do my gears because im just gonna put it on while im switching mid pipes so i dont have to take the midpipe off again later
oh awsome... so now i dont need to shell out that extra 200 bucks that i dont even have just to save some time... ill get the drive shaft with my gears in a couple months.... thanks md
