Car Wouln't Go into gear: New BBK quadrent?
I searched around the board a little and couldn't find any help.
I recently had installed a centerforce stage two and a BBK Adjustable
Clutch Cable Kit. About 400 or 500 miles later i got on it for the first time and had a perfect launch with mynew tires. When i tried to throw it into second it felt like the synco failed and wouln't go into 2nd. Now after that launch it is really hard to put in gear and drive your have to shift at optimum RPM's from gear to gear or it will not go in or if you force it, it will grind. I think it might have to do somthing with the cable adjustment and the launch with the new tires.
Does anybody know how to adjust a BBK or Steeda (same thing) clutch cable?
Preety sure that is the reason i am going to go from there with it but anywayz if anybody else has opinions or similar problems i am open for suggestions.
Thankyou for your time guys,
Josh from Maryland
Josh from Maryland
RE: Car Wouln't Go into gear: New BBK quadrent?
ORIGINAL: white02stallion
i cant put the stock cable back in because the mechanic threw it away when i asked for it back. i tightened the cable and it is better than it was before.
Back to your issue. The problem will returm. All aftermarket cables are junk.
Figure8allday
08-22-2015 11:11 AM
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
