spark plugs and wires
Old 12-31-2004, 05:05 AM
GT1999
GT1999's Avatar
Default spark plugs and wires
since this topic came up in apost i figured we could start a thread on it....
what are some good performance plugs and wires that dont cost all the money in the world....
i saw NGK IX iradium plugs for about 6 bucks each... are they really good plugs?
also what are some good wires that dont cost a load of money..
GT1999 is offline
Old 12-31-2004, 05:09 AM
GT1999
GT1999's Avatar
Default RE: spark plugs and wires
also what difference does it make if the plug wire is 8mm or 8.8 mm or 9 mm ?
GT1999 is offline
Old 12-31-2004, 05:13 AM
GT1999
GT1999's Avatar
lol ALSO, how often do u need to change ignition wires? damn it all these wires i dont knwo anything about ... someone teachme
spark plug wires.... ignition wires... how often do u need to change them and what are the best performance ones to go with ,, brand and size. thanks guys
GT1999 is offline
Old 12-31-2004, 05:21 AM
grabbem88
grabbem88's Avatar
i use msd....once a year i chang them out......good x-mas gift to my dad. pack rat!
grabbem88 is offline
Old 12-31-2004, 05:32 AM
GT1999
GT1999's Avatar
MSD plug wires or ignition wires or plugs or all 3 ... or are plug wires and igniton wires the same thing? and what size is good to use on a 99GT..
GT1999 is offline
Old 12-31-2004, 11:33 AM
vfast
I ♥ Acer
vfast's Avatar
well whem looking at good plug wires it's not size be less resist in the wire..you want the lowest ohm wires you can get that doesn't interfear with your radio..as for plug and plat. plug is good..you want a plug that warms up fast is about all you can hope for...plugs in a stock engine will not increase horsepower....current to it will though
vfast is offline
Old 12-31-2004, 01:22 PM
96mustanggt46
96mustanggt46's Avatar
Since you have a 99+ gt you do not have spark plug wires. i have NGK plugs and they work varry well so far.
96mustanggt46 is offline
Old 12-31-2004, 02:36 PM
Sidewayz6.0
Super Moderator
Sidewayz6.0's Avatar
If you look, the 99+ GT's have the coil pack right on top of the plug. So you don't need wires. Just buy some new plugs. If you need them. Depends on what you've done, or are going to do to the car. Nitrous, or a blower...You need a plug thats a couple of heat ranges cooler. If it's stock, then don't really bother. Just put in what is supposed to be in there.
Sidewayz6.0 is offline
Old 01-01-2005, 05:45 AM
neogenic83
neogenic83's Avatar
U should change the plug boots if u wanted too. I have 55K. I inspected mine and they looked brand new so i don't think they actully go bad.
neogenic83 is offline
BOB ROME
07-26-2023 01:54 PM
jwog666
12-27-2021 08:09 PM
Matt's 95 Stang
10-05-2015 07:16 AM
Dathan
10-05-2015 05:52 AM
lmurf60
09-24-2015 10:07 PM
Quick Reply: spark plugs and wires
