VERY little time...need help fast! (Passnger side exhaust)
I got the driver side installed but now me and my buddies cant get the piece that goes over the axle on the passanger side! It just won't go over. So far we got it on rhino ramps and used a jack on the same side to relieve most the weight off the tires...it worked wonderfully with the driver's side but not so much the pass. side. Any tips please?
RE: VERY little time...need help fast! (Passnger side exhaust)
Pick it up all the way so the wheel is hanging free, you may have to pull the bottom bolt from the shock (but be careful cause the spring can come out once you do this).[/align][/align]I have also sometimes removed the little vent fitting from the axle...[/align]
If you don't mind cutting it then go ahead and do that. I had to cut mine off right near the axle because allI had was ramps. Makes getting that part out extremely easy.
ORIGINAL: massmustang02
Keep the car on Jack stands, place your actual floor jack under the passenger shock mount and jack it up until it starts to come in contact with the shock mount. Remove the lower mounting bolt for the shock.Use the floor jack to slowly lower that side of the axle until you have the clearance to put the hump over the axle. Then use the jack to get the axle and lower shock mount to realign, tighten everything back up.
Oh my bad. I thought he was having trouble getting that side off. Oh well he figured the problem out anyways. Make sure you post some clips so we can hear it.
Galactic
04-29-2019 02:56 PM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
