95 Crown Vic 4.6 engine in a mustang?
I have tried to find out everywhere if this would work. I own a 95 mustang v6 and a 95 crown victoria. The mustang's got a rod knocking in the engine and I expect it to blow any time. My crown victoria has a 4.6 liter v8 engine in it but I'm not sure if it would work in the 95 mustang. (The crown vic's body is junk)
Would the swap work? Would a mustang transmission fit with the engine? What about the wiring harness and computer? Would I be able to use the stuff out of the crown victoria? What mustang parts could I use with the engine?
And buying another car isn't an option. There is a mustang graveyard nearby and they seem to have everything except engines, so the parts would be easy to come by.
Help me out please.
Help me out please.
RE: 95 Crown Vic 4.6 engine in a mustang?
Nevermind,i thought you said '96 GT for some reason. You'll need the motor mounts,different bellhousing for the tranny if it's a T-5,4r70w should bolt up easily. you'll need the wiring harness,throttle cable,a/c lines,yadda yadda yadda.
the 4.6 started in crown vics i believe in '92. it was more of a luxury motor im guessing that took place of the 5.0 mustang motor due to emissions in '96.
