RWHP???
RWHP???
Getting a new MMR shortblock on my setup.
I currently have PI heads/intake and my Vortech S/C will have a pulley swap from stock 3.60 to 3.125. Right now I'm putting down about 360ish(8psi) but take into consideration my compression is 10.5:1 because of PI swap. New block will be 8.9:1 but I'll be adding a Powerpipe and I'll still have the Snow kit! No porting of heads.[/align]
RE: RWHP???
What are all your supporting mods?(exhaust etc?)
Assuming full exhaust etc you will outrun your pump with that setup.With LTs, midpipe,catback, intake boltons (t/b and plenum) and a good tune your talking 470-500 WHP.
Do the fuel system, and assuming the snow kit is as good as a i/c you should see 550~ WHP.
With your 360 WHP number though I assume your running stock exhaust or something? With the snow kit, even at 8 PSI, and your PI parts on there you should be making more than that unless its being pushed thru a stock exhaust system. Your CR shouldn't be that much of an issue ATM since you have the snow kit (and it helps detonation so much).
RE: RWHP???
Your not gonna see 600 WHP on a stocktopend(even PI) car with a V2, espcially without a I/C (even with the snow kit).
Without cams 550 is PUSHING it pretty hard. With the I/C you might get it done, but it usually takes a set of aftermarket cams to get there.
