Bullitt Susp. Kit + SLP Cat Xpipe? Low?
RE: Bullitt Susp. Kit + SLP Cat Xpipe? Low?
ORIGINAL: Aereon
better handling and aftermarket uca's do not go hand in hand when your talking about mustang handling.. Most people will delete the uca's as they are placed in a horrible spot and do neither of the job they are supposed to do well... (locate the axle and control windup) Aftermarket UCA's are much more rigid, causing the rear to bind much more easily on simple turns or corners.
I did not say install was over a grand, your looking at about 400-600 depending on where you go for install and alignment. I said 1k-1.5k parts/labor.
ORIGINAL: jpmustanggt
The bullitt kit is a good kit for someone that wants just a little bit more handling. IMO I would go ahead and get another kit. U/L control arms, shocks and struts (adjustable if you have the cash), subframe connectors...
It really depends on what you want from the car tho.
Going from the stock stuff to the full syspension, even with my setup (not exactly a handling setup with the fox 4 cyl springs and roush drag racing rears) it still handles x10 better than it did before. I think your getting information from people that are going with 3 link setups etc and acutally road raicing the car, but what your talking about has little/nothing to do with a street/drag racing car.
Road racing (on a track) is one thing, but on the open (public) roads your not going to be able to tell the difference. The traction (from the pavement) is simply not there, and if your pushing your car hard enough on open streets to notice something like this you arn't going to come back and post about it... cause your gonna go face first into a carload of crumb munchers and mommy in the 5200 pound SUV
ORIGINAL: 2000GT4.6
You have stated this over and over again, but as I have stated over and over again neither myself nor any other forum member that has upgraded the UCAs has had these issues.
ORIGINAL: Aereon
ORIGINAL: ChrisZio04GT
Hey Guys, I live in the south suburbs of Chicago and its really not that bad around here with speed bumps and everything, but I really want to get the Bullitt susp. kit because I did alot of reading and seems like best bang for the buck, also it doesnt lower the car that much and is pretty good for just a DD car, for 500 dollars and I work in a shop so install would be nothing sounds perfect.
I never once bottom out with the xpipe and I want to keep it that way, I was wondering if anyone else had this setup with the catted xpipe? also is there anyway you can get the xpipe to go up a little higher or is it impossible?
Thanks in advance,
Chris
Thanks in advance,
Chris
For the price, go for it.
All I am saying is that I have not heard of anyone ever having an issue with the UCAs after acutally doing the install. There are a LOT of forum members that have done this mod and been happy with the results.
I cannot say for 100 percent sure that doing the UCAs helped the handling/launch of the car, as I did my entire suspension all at once, but there have been no negitive effects on the car that I can tell. I have tried throwing the car around a few turns with the shocks/struts set to 8/8 (STIFF) and have had no issues with loosing traction or anything else, the ride feels about the same (unless you have the shocks/struts set to stiff/loose) and it doesn't make any strange noises.
The upper arms are no doubt more stiff with aftermarket ones than the stockers, and thats the entire idea, to take flex out of the drivetrain so you put more to the ground. Even with the stock arms the side to side movement is so small I cannot see how changing out to stiffer bushings and stiffer arms is going to effect suspension on a typical street car that much. Perhaps on a road racing situation where you need 110 percent of availble traction and are constantly throwing the car into turn after turn you would see problems, but I don't see how its going to apply on a street car.
Its just my .002 cents, but with a suspension mod if it didn't work people wouldn't buy it. I can see people doing it with stupid stuff like spacers etc, but control arms are a bit more serious (and pricey if you get the fancy steeda etc ones). If it didn't work, big companys like salleen/roush/steeda wouldn't sell them or equip them on their factory built cars. .
ORIGINAL: 2000GT4.6
I agree with you that the point is to put more down to the ground and minimize axle movement, but what happens when your in a turn? those stiffer uca's will be less accomodating if say, you had to swerve.
These are not my pictures but they are what I can find atm,
http://www.miracerros.com/mustang/t_suspension.htm#Rear
This does a pretty good job of summing it up.
From my standpoint not touching your uca's is better than wasting your money on aftermarket ones. There are actually some guys on c-c.com that do drag as well, and from what I've gathered and hypothesized, the rear suspension of a mustang is a good comprimise, cost/performance wise for a daily driver, but if your looking at better times, whether at an open track or on a strip, your gonna hafta find a way to optimise your rear suspension setup in order for you to run at your best. And the stock 4 link, short of relocating the mounting points of the UCA's to the chassis, will only hinder your car's performance.
You don't have to agree, I am only offering what I've learned from researching how to make my car perform better.
From your link:
Its just not a concern on anything but a road race car. The suspension bind that is possible only happens on a car that can acutally hold the road hard enough to make it do so. Your typical street tire/stock style supension car simply cannot offer that kind of control and handling style traction to permit the suspension to move enough that its nessicarry.
Regardless of all this, who would want to road race a car, take it seriosly (seriously enough that the car handles well enough to cause the problems) and even leave the 8.8 in place? With the availbilty of nearly free IRS setups from almost any cobra owner you would be a fool to acutally stay with the stock 8.8 setup (or even a 3 link/5 link etc) when you can go IRS and have an independant rear that will handle uneven surfaces thru a turn.
Your simply reading too much into it. Having upper control arms is superior to the stock ones from a drag racing standpoint, and from a street driven standpoint it improves launch traction without comprimsing streetably or achivable handling traction.
So far as not being able to achive acceptable performance from the 4 link setup with just aftermarket parts, your way off there. I would call 1.6 and 1.5 60' times pretty acceptable on a street driven car, and thats easily achivable with even the setup I have (with the proper tire). Hell, MDvaldosta went 1.6s and 1.5s on MT slicks with a VERY cheap setup (fox monroe shocks in the back, adjustables in the front, blue oval (150 a set) uca/lca's and foxbody 4cyl shocks).
If you use your car in open track or autocross competition, you'll probably want to leave the stock upper control arms alone and install only new lower control arms. The stock rubber bushings in the upper arms continue to allow the axle to articulate through its full range of motion in turns, while the new lower arms improve axle location. One popular lower arm design (illustrated below) uses segmented poly bushings on the chassis end and spherical bearings on the axle end. This combination has been found to improve rear axle location without any significant increase in suspension bind.
Ford minimizes this suspension bind by using compliant rubber bushings in both the upper and lower control arms. These relatively "soft" bushings acommodate the necessary motion of the control arms during body roll. However, they also permit wheel hop on hard launches and horizontal axle deflection in aggressive turns. Axle dampers (quad shocks) were installed on V8 Mustangs to eliminate this wheel hop, but nothing was done by Ford to cure the horizontal axle deflection. That deflection is responsible for the "tail-wagging" sensation well known to anyone who has driven a late model Mustang aggressively.
ORIGINAL: LetThePoniesRunFree
Check out the pics in my gallery. I'm running the Bullitt springs/struts/shocks/sway bars on my DD. I also have Granatelli upper/lower rear ca's. They have urethane bushings but are the 3 piece style so bind up is suppose to be limited.I'm running well over 400rwhp without any problems what-so-ever in the handling dept. for what I usethe carfor. The Bullitt set-up is WAY better than what the GT comes with from the factory. Does it have it's limits? Hell yes, but I have to push the car way beyond what is safe and saneon public streets to get to those limits. Visually I would like my car to have a lower stance but every time I scrape my chin spoiler I thank goodness I don't have shorter springs.
Thanks in advance,
Chris
Thanks in advance,
Chris
I think your reading way too much into it, I am simply offering that aftermarket uca's are worthless, those track times can be atributed to many different factors. Yes, you can go with an irs setup, is it ideal, no. The ford IRS is far from perfected. It has taken a friend of mine close to 20 hours on the weekend just to make it somewhat more reliable than the crap the stock irs is. I am not here to debate any form of misinformation that company's like steeda would like you to believe. Call MM and Griggs, that have engineers working and studying the rear kinematics of a mustang and see what they have to say about buying aftermarket uca's to improve the car's launch/handling. I am simply offering another side to the subject.
how many young mustang gt owners have you seen drive like a granny.. There are those that drive like they are supposed to and in their case you can have the most heavy duty uca in there and it wouldnt matter much, if you took corners at the recommended speeds that even a pinto could navigate.
aereon has a point any car can wheel hop if pushed to hard .best way to learn what you and the car can do handling wise auto cross drag racing is best to try on like a test and tune day
I dunno what else to say. Personal experence simply proves what your saying is wrong. It doesn't hurt performance in any way (for a drag/street car), it stiffens the rearend signficiatnly, and it helps with launch.
Its just been done to many times with absolutly no negitive results for what your saying to be true. I can accept that companys would build a part that does nothing, but this is simply not the case in this situation. Salleen/roush etc etc would not bother putting them on the cars they sell if it was not helping (why waste the money, and its not like they would charge less for the same car without the UCAs).
Simply put, they improve performance in a straight line and don't hinder handling (at all from what I can tell) significantly on anything but a all out circut track car.
The aftermarket UCAs allow you to remove the quad shocks (if notthing else drop weight and allow a wider tire to be used), improve launch, lighten the car (if you buy the really $$ ones that are aluminum) and reduce wheelhop. If your out there pushing the car to 10 10ths of its capabilty on a road course you MIGHT have a problem with the UCAs compared to the stockers... but probably not.
