Bullitt Susp. Kit + SLP Cat Xpipe? Low?
Hey Guys, I live in the south suburbs of Chicago and its really not that bad around here with speed bumps and everything, but I really want to get the Bullitt susp. kit because I did alot of reading and seems like best bang for the buck, also it doesnt lower the car that much and is pretty good for just a DD car, for 500 dollars and I work in a shop so install would be nothing sounds perfect.
I never once bottom out with the xpipe and I want to keep it that way, I was wondering if anyone else had this setup with the catted xpipe? also is there anyway you can get the xpipe to go up a little higher or is it impossible?
Thanks in advance,
Chris
Thanks in advance,
Chris
RE: Bullitt Susp. Kit + SLP Cat Xpipe? Low?
You will be 100 percent fine with that setup.
what are you wanting to do with the car though? The bullitt setup is OK, but its nothing spectaular. For a little more money you can do a true aftermarket setup and have a much better car.
Were you looking at that full Bullitt suspension kit I guess? IIRC that only gives like a 0.75 inch drop, thats not much at all. Unless you are set on the kit, I'd get at least C springs, which are either a 1 inch or a 1.25 inch drop (I don't remember exactly)
lols.. I can fit 1 1/1 fingers in the wheel gap in front and 2 in the wheel gap in the rear.. my xpipe scrapes everything! It's about 1 1/2 to 2"'s off the ground. I'm planning on asking a muffler shop to tuck the slp x pipe and the slp catback up a bit.. gonna switch from lmII's to lmI's at the same time. The bullitt kit is a great budget setup, if your gonna do the work yourself. If not look to spend up to 1k-1.5k for parts and labor.. I spent 1.4k on my coilovers and installed them myself following the directions mm provides.
In order for your xpipe to be tucked higher your gonna have to have a welder or a muffler shop cut and reweld some of the piping. It's better to have them do that than to leave your exhaust on a speedbump.
ORIGINAL: Aereon
The bullitt kit is a good kit for someone that wants just a little bit more handling. IMO I would go ahead and get another kit. U/L control arms, shocks and struts (adjustable if you have the cash), subframe connectors...
It really depends on what you want from the car tho.
ORIGINAL: jpmustanggt
I did not say install was over a grand, your looking at about 400-600 depending on where you go for install and alignment. I said 1k-1.5k parts/labor.
It is my dd car and I am going to get a procharger in a year or so, I just wanted to do little to the suspension so it isnt that stock I also dont want to spend over 700 bucks, 500 for Bullitt kit and 100 for subframe connectors. this is going to be my DD not really going to take it to the track thats why I was just going to get this package.
Is there any other packages out there that are a little better? Maybe around 600 bucks or so?
you could always sell your underdrive pullies to add to the suspension fund (as you'll need to take them off if you get a supercharger anyway)
I personally like the way my car handles now and I have minimal suspension work done.....steeda sport springs, tokico 5-way S/S, subframe connectors, caster camber plates and bumpsteer kit....it wasnt too expensive either and other than the subframes which i had welded in at an exhaust shop, me and my good friend spent an afternoon installing everything.
i use my car for a daily driver, no track duty.....but its a lot more fun to throw around now.
try http://stangsuspension.com/store/com...?idCategory=27
and check out the packages they offer....thats where i got most of my stuff
